It is currently Sat Apr 20, 2024 2:06 am
 Post subject: Multiplier Glitch..
PostPosted: Mon Jul 14, 2003 8:00 pm
So, I've been writing my own personal ROM editor and I came across a small problem.
During my save routine beta testing, I decided to be wild and put a 10.85 ms pulse duration on at 500rpm@26inHg.
Well, that was dumb. It really messes things up. I'm not sure how to go about fixing it. Maybe just an error checking routine to hook "invalid" or obscene values.
..I checked GhD and it has the same problem, only, that it's much worse because it actually crashes the program with a "Runtime Error '6': Overflow" losing all data.
Anyway.. just thought I would throw this out there.
 Post subject: Re: Multiplier Glitch..
PostPosted: Tue Jul 22, 2003 1:22 am
I ran into this same problem with Ghettodyne. I was actually wanting to retard the ignition as much as possible and give a large pulsewidth to dump in fuel and then spit flames. Can't enter more than 2.07ms for the pulsewidth on the first column.
-Michael
PostPosted: Tue Jul 22, 2003 11:29 am
Yeah, GhD could use a bit more error handling, but hey, you're putting in 10.85 ms for idle! I never thought of someone doing that! :-)
Multiplier changes are in the next release...I'm working on an auto discovery of the multipliers so it uses the best one possible based on the value entered in. This can be over-ridden of course for those curious folks. Release date TBD.
Mike
PostPosted: Fri Aug 08, 2003 11:25 am
Use:
On Error Goto
for error handling... just in case you didn't know...
Example:
Sub MySub()
On Error Goto ErrorHandler
' Do your stuff here
Exit Sub
ErrorHandler:
' Do you error handling here
End Sub
