Yeah, a while ago I asked Mike how it was going, and he told me his boost version was having problems coming down off of boost, if I heard him right. He said he had an inferior version ready to go, based on the MAP scaling concept, but he hadn't released it because the rez was low. I said, Heck, half the stock NA table is duplicates of one kind or another, and he said Yeah you're right, good point, and went ahead and released 2.2.1. And sure enough, the rez hasn't turned out to be a problem, it's this vacuum based ignition glitch.
That means the good news is, he has a high rez boost version in progress, and when he gets the kinks worked out of that, not only will the ignition glitch go away, the rez will improve.
