Ok, I have to respond to this for obvious reasons:
1) Inches of Mercury *IS* how you measure pressure. There is no negative and positive values. If you need a negative sign then you should not be messing with the tune at all since you don't have a good understanding of how pressure is measured.
2) Read the readme file, or the help section, or both. It states GhD doesn't make a backup. Both help files state to make a backup copy before you ever begin. If that is something you need to ask how to to do, then we have bigger problems.
3) I made GhD non-resizable for a reason. If the whole program doesn't fit on your screen then you are running a resolution under 800x600 which I didn' think anyone did anymore! I will take this into consideration for V2.0
4) The revision if GhD you have does not mess with the open loop/closed loop routine at all. It basically takes a COMPLETELY stock 91 Si Bin and lets you modify the fuel and ignition tables, and the rev-limit. That is all it does. Again, the bin it comes with is completely 100% stock, dumped streight out of my 91 Si ECU. Not changed at all, not even commented. Did I mention it was un-touched? All that you are doing is changing the fuel and ignition settings for closed loop operation when the throttle positioning sensor is pasted ~20%. The next release supports a ton of other options, but still has bugs that need to be weeded out.
Joseph: I'd love for you to beta test V2.0 My domain is all jacked up so I haven't been able to reply to your email yet
I'll e-mail you when it's back to normal (few days).
Lastly, I'm always up for suggestions on how to make GhD better.
Mike
