It is currently Tue Apr 16, 2024 5:50 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: timing calculation.
PostPosted: Wed Mar 05, 2003 4:29 am
i was wondering how you calculated the timing? in other words hex to btdc.
any info would help, i did a search but couldn't find any thing, and you seem to be quite knoledge able. thanks
 Post subject: Re: timing calculation.
PostPosted: Wed Mar 05, 2003 2:48 pm
first convert the hex to decimal. then use this formula:
ignition = ((x-15) * .36) where x = decimal equivilent of hex value
Mike
PostPosted: Wed Mar 05, 2003 6:28 pm
thanks allot mike!
PostPosted: Wed Mar 05, 2003 9:17 pm
sorry to be a pest man, but i cant figure out how to calculate stock revlimiters. i can calculate custom ones but i cant figure out stock ones.
costomRevLimiter = 1920000 / revLimit
revLimiter = ????????
thanks man
PostPosted: Thu Mar 06, 2003 1:49 pm
hex = (1920000 / RPM) - multiplier
So... If you want a 3200 RPM limit, 192000 / 3200 = 600
600 - 512 (which is the 02 multiplier 256 + 256) = 88
88 in hex = 58
02 as multipler, and 58 as databit.. == 3200 RPM limit.. and so on.
Thanks to Mike for information..
PostPosted: Thu Mar 06, 2003 4:24 pm
if i had a program with the revlimit already changed, how can i figure out what it's changed to?
for instance. take a stock rom get the high and low bit then concatinate them: 01 + 03 = 1030. where would i go from there? i would just like to see what some of the revlimits are in some roms of mine. and it would just be nice to know.
