It is currently Thu Apr 25, 2024 3:07 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Wed Apr 05, 2006 1:38 am
well i read for a few hours of peoples problems
and none seem to fit mine or show the resolve
chipped p06 crome free
quickdatalogging added
checksum removed
j12 tried in & out (its in now)
serial cable measures 3.3v from the pc on #3
one of the lines gives about 1v...the other about 0.5v
and naturally the ground on #1
switched up the tx/rx lines with every change...
i get nothing
no drivers are needed based on what i read
i have two serial ports...i disabled #2 to be sure of irq steering
zero confilcts...#2 disabled in bios and device manager...to be sure
p3 650mhz 392mb xp pro
do i need to enable a modem for com1 ... ?
connecting the cable to the comp DOESN'T bring up hardware install
searching for new hardware DOESN'T do squat
version 5.8.41
thanx for any/all help
I have tried a dku-5 with the same results
is there a service i need to enable for TTL communications or something
i've been around computers enough...this seems like a pc malfunction/disfunction
but its a fresh (i mean FRESH) install of xp pro
its an older m/b from 98-00 micron se440bx
yeah i run a desktop in my car...since 2000
Users browsing this forum: No registered users and 9 guests
