It is currently Thu Apr 18, 2024 12:11 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: cant get it to work!!
PostPosted: Sun Feb 26, 2006 11:43 pm
okay... for a while i was having trouble getting ECU control to work with the usb adapter i bought from xenocron.com... it didnt want to connect... i finally figured it out (remove checksum) and ecucontrol connects and starts getting data...
however, the data it is retrieving is completely wrong.
-the RPM constantly stays at 81 rpms even when i rev it.
-the speed stays at 51 even when i am going nowhere.
-pressure stays at -11.xx
wtf is wrong with this??
and oh ya, i have crome, but i dont have crome pro, and im running ECU Control 5...
95 civic DX
d15b7
chipped P06 ECU, P30 base rom (crome)
Quick datalogger +RTP
Remove checksum routine
PostPosted: Mon Feb 27, 2006 3:46 am
figured it out: had to cut j12
PostPosted: Fri Jul 21, 2006 6:10 pm
i just had the same problem.. thank you for posting the solutioin when u found it.
PostPosted: Mon Aug 14, 2006 9:28 am
i just had the same problem.. i will remove the jp12 for test.
