It is currently Mon May 13, 2024 3:22 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: cant get crap working
PostPosted: Sun Oct 23, 2005 7:44 pm
i got evreything i need but i cant get this damn thing working. i can chip it and switch between the NG55, NG60, and stock. curently i'm running NG55 because thats what ecucontrol wants. i'm running a chiped PS9 ecu and a serial conection. i have tried evrey thing thats changeable. and have red evrey word of text here on it AND I STILL CANT GET IT WORKING. no gauges, loging, turboedit, nothing :? plz i dont know what to do. i'm at my witz end.
P.S. i'm posting in here b/c i wana get ecucontrol working. the car (stock wise) is perfitly sound. so i know it's somthing wrong with the setup not the ecu or car.
PostPosted: Mon Oct 24, 2005 10:29 am
What type of serial connection?
which serial chip?
Have you tried using Hyperterminal with the RX and TX leads shorted together?
Have you tried swapping RX and TX leads at the ECU?
99% of the first time problems are in the connections - soldering job, cable connection or pin order. Once you get everything straight, it will be no problem from then on.
PostPosted: Mon Oct 24, 2005 12:45 pm
just a normal 232 conection. trying 9600, 8, n, 1.
which serial chip?
the chip# is: ST232ABN
yes. EDIT: just got it working. i can see what i type.
yes but it didnt work.
PostPosted: Wed Oct 26, 2005 1:50 pm
i've tried evreything i can think off and i still cant get it working :? i'm about to give in the towle.
PostPosted: Wed Oct 26, 2005 2:30 pm
Did you try the Hyperterminal test at the 232 leads or the leads going to the ECU?
PostPosted: Wed Oct 26, 2005 3:02 pm
yes and that works but i'm getting nothing from the ecu.
i got 2 computers, one running ecucontrol, other running hyperterminal. and i can see that ecucontrol is sending out data but not receving any.
PostPosted: Tue Jan 17, 2006 1:12 am
so what did you do to get it working? I think im having the same problem, and the only wire i know is what on my cable is the ground. argh.
and what is this hyperterminal
PostPosted: Tue Jan 17, 2006 10:17 pm
i never got it working. i gave up :cry: hypertermainal is a terminal program for windows. look undder accessories and comunicaons.
Users browsing this forum: No registered users and 4 guests
