It is currently Sun Apr 22, 2018 9:56 pm
PostPosted: Mon Oct 24, 2005 5:50 pm
I had a p06 ecu converted to p28 to run my D15B vtec turbo setup. My ecu was chipped by xencron (chris) and also purchased the usb dataloggng cable. I am able to connect using ecu control 5.4.1 but the data is very jumpy and unreliable. Please explain to me the basic settings needed for data logging. I have also used other programs with the same result free log, cuddle, all seem to connect then display wrong jumpy data. I watch the gauges and they are not real time like they should be and the readings are jumpy and incorrect. Please give me a push and I should be good to roll on.
PostPosted: Mon Nov 28, 2005 12:18 am
31 views and no suggestions? Whats up with that?
PostPosted: Fri Jun 23, 2006 7:32 pm
PostPosted: Thu Oct 19, 2006 10:14 am
Check the baudrate in windows from the comport 38400 ( not sure exactly) works fine for me other wise try 19200 it should work fine to.
