It is currently Fri Mar 29, 2024 7:11 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Feb 23, 2006 6:22 pm
basically, yes!
PostPosted: Sun Apr 16, 2006 8:52 pm
this is swwweeet! I really like the program. I've been trying it out and have a couple bugs. btw im using a PLX wideband and P06 ECU with a serial port for datalogging on my 93 accord.
1. Speedo conversion from metric is not precise. Km works out okay, but the MPH are way off once you're over about 50.
2. The AFRs guage still doesn't move.
3. An exception handler for when i unplug the device. I was datalogging and crashed the program before I was able to save the datalog because it had an internal error when I pulled the USB cable out of my laptop before disconnecting datalogging. My fault... but if its an easy fix...
4. There are hundreds of blank rows in the datalog when I open it with Excel 2003.
5. Related to #5 above, but when datalogging, the display will show a lot of blank lines.
6. On the datalogging tab, the scroll bars don't really work. Its as if they don't fit in the window. Even maximized on my highest resolution I can't seem to reach the scrolldown arrow.
7. possible feature: save ECU and Wideband settings when you close the program so you dont have to select them each time?
8. user interface: Okay this has been mentioned before but a lot of people will be trying to use this while they are driving so if the checkboxes could be 4x as big, and the buttons huge it would make the roads safer for everybody!
THANKS FOR THE COOL SOFTWARE.
PostPosted: Wed May 03, 2006 6:15 pm
i can't seem to download this. broken link?
Users browsing this forum: Bing [Bot] and 8 guests
