It is currently Fri Jul 20, 2018 10:04 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 63 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Tue Oct 11, 2005 6:27 am
Site Admin
Ok, needs testing because I canot test ithere before. I simply added (tried anyway) Ng60 support and Wideband logging support to the standaone version.
as for 5.8.35 I also added Column and Row of fuel and ign tables logging.
fixed the "Enter number" problem.
Added Air Fuel offset correction.
Fixed the slow logging.
Ok, I may have fixed the TPS setting for logging to the file, but i'm not sure.
and I may have fixed the hanging in the logging too
5.8.37 :
Fixed the sensor selector that wasnt selecting the right sensor to datalog.
5.8.40 : Fixed Unit Selection and VSS bug.
5.8.41 : Improved GUI, Removed Obsolete Code, Removed the Unit in the Datalogging GRID.
http://www.ecucontrol.com/download/EcuControl5.8.41.zip
PostPosted: Wed Oct 12, 2005 2:19 am
I would like to test but I'm using an LC-1. I did look though. What's the chance of getting that "raw o2 voltage" tab to work?
Also would love to see this have adjustable default settings.
I will test all I can.
94 gsr
p72
uberdata
lc-1
PostPosted: Wed Oct 12, 2005 9:09 am
The raw voltage seemed to work perfectly for the Turboedit plugin so its likely it will work on this standalone version :D
PostPosted: Wed Oct 12, 2005 9:42 am
Site Admin
YEs and that's exactl what I want people to test...
PostPosted: Wed Oct 12, 2005 12:52 pm
Sorry just replying to 8man there. Im in France at the mo but ill test when im back home on OBD1 and OBD0.
This file loads a 5.8.27 version though is that correct?
PostPosted: Wed Oct 12, 2005 3:12 pm
<--- Will test as soon as my Azenis come. Blowouts suck. :roll:
I ASSume that with a raw voltage, we're a step away from converting that into AF ratios for any number of sensors.
Also, maybe this is a dumb question, but I'm using the datalogging roms from BRE in my PR3, which reportedly use a "different" datalogging. Any idea if it is compatable with EcuControl? My datalogging has been giving me a fit lately, so I don't know what is working and what is not.
PostPosted: Wed Oct 12, 2005 5:18 pm
FINALLY! another release... i will test this RIGHT NOW!
PostPosted: Wed Oct 12, 2005 5:30 pm
I can connect, but not log. Get a runtime error '424'.
PostPosted: Wed Oct 12, 2005 5:39 pm
Site Admin
ok, i'll fetch my test ecu and debug.. yaawn...
PostPosted: Thu Oct 13, 2005 1:24 pm
Ditto. Then the program craps on my face and closes.
PostPosted: Fri Oct 14, 2005 12:04 am
Site Admin
FIXED.
See first post.
PostPosted: Fri Oct 14, 2005 4:51 pm
MAP logging doesnt work... neither does the Vac/Boost guage; assumng its cause the map isnt working..
Logs VERY slowly, one sample every second or so.
PostPosted: Fri Oct 14, 2005 5:30 pm
Same here.
Sorry about before, I couldn't select raw voltage and plx was new, so I assumed that was what needed testing.
PostPosted: Sun Oct 16, 2005 11:37 pm
Site Admin
Fixed again, see first post for update.
PostPosted: Mon Oct 17, 2005 2:01 am
I just ran out to test this quick. The raw voltage seems to work great (stock O2 anyways), some things that I noticed is that it seems to start loging at about 10 percent of what I had the min TPS set at (eg. set at 10-19 and starts logging at 2, set at 20-29 and starts logging at 3). Another thing I ran into is that when logging sometimes it is like the inputs get stuck when using "log to file" (none of the values change except time). If I uncheck "log to file" the values start changing, but after rechecking it it does the same thing after about 4 lines. Restarting ECU Control usually fixes this for a while.
