New Beta release 5.8.41 - Standalone Version http://forum.pgmfi.org/viewtopic.php?f=10&t=7543 |
Page 1 of 5 |
Author: | Synoptic [ Tue Oct 11, 2005 6:27 am ] |
Post subject: | New Beta release 5.8.41 - Standalone Version |
Ok, needs testing because I canot test ithere before. I simply added (tried anyway) Ng60 support and Wideband logging support to the standaone version. as for 5.8.35 I also added Column and Row of fuel and ign tables logging. fixed the "Enter number" problem. Added Air Fuel offset correction. Fixed the slow logging. Ok, I may have fixed the TPS setting for logging to the file, but i'm not sure. and I may have fixed the hanging in the logging too 5.8.37 : Fixed the sensor selector that wasnt selecting the right sensor to datalog. 5.8.40 : Fixed Unit Selection and VSS bug. 5.8.41 : Improved GUI, Removed Obsolete Code, Removed the Unit in the Datalogging GRID. http://www.ecucontrol.com/download/EcuControl5.8.41.zip |
Author: | 8man [ Wed Oct 12, 2005 2:19 am ] |
Post subject: | |
I would like to test but I'm using an LC-1. I did look though. What's the chance of getting that "raw o2 voltage" tab to work? Also would love to see this have adjustable default settings. I will test all I can. 94 gsr p72 uberdata lc-1 |
Author: | jonnyvtec [ Wed Oct 12, 2005 9:09 am ] |
Post subject: | |
The raw voltage seemed to work perfectly for the Turboedit plugin so its likely it will work on this standalone version |
Author: | Synoptic [ Wed Oct 12, 2005 9:42 am ] |
Post subject: | |
jonnyvtec wrote: The raw voltage seemed to work perfectly for the Turboedit plugin so its likely it will work on this standalone version
YEs and that's exactl what I want people to test... |
Author: | jonnyvtec [ Wed Oct 12, 2005 12:52 pm ] |
Post subject: | |
Sorry just replying to 8man there. Im in France at the mo but ill test when im back home on OBD1 and OBD0. This file loads a 5.8.27 version though is that correct? |
Author: | drdisco69 [ Wed Oct 12, 2005 3:12 pm ] |
Post subject: | |
<--- Will test as soon as my Azenis come. Blowouts suck. I ASSume that with a raw voltage, we're a step away from converting that into AF ratios for any number of sensors. Also, maybe this is a dumb question, but I'm using the datalogging roms from BRE in my PR3, which reportedly use a "different" datalogging. Any idea if it is compatable with EcuControl? My datalogging has been giving me a fit lately, so I don't know what is working and what is not. |
Author: | rudeludenotmeanthough [ Wed Oct 12, 2005 5:18 pm ] |
Post subject: | |
FINALLY! another release... i will test this RIGHT NOW! |
Author: | rudeludenotmeanthough [ Wed Oct 12, 2005 5:30 pm ] |
Post subject: | |
I can connect, but not log. Get a runtime error '424'. |
Author: | Synoptic [ Wed Oct 12, 2005 5:39 pm ] |
Post subject: | |
rudeludenotmeanthough wrote: I can connect, but not log. Get a runtime error '424'.
ok, i'll fetch my test ecu and debug.. yaawn... |
Author: | Quagmire [ Thu Oct 13, 2005 1:24 pm ] |
Post subject: | |
Ditto. Then the program craps on my face and closes. |
Author: | Synoptic [ Fri Oct 14, 2005 12:04 am ] |
Post subject: | |
FIXED. See first post. |
Author: | rudeludenotmeanthough [ Fri Oct 14, 2005 4:51 pm ] |
Post subject: | |
MAP logging doesnt work... neither does the Vac/Boost guage; assumng its cause the map isnt working.. Logs VERY slowly, one sample every second or so. |
Author: | 8man [ Fri Oct 14, 2005 5:30 pm ] |
Post subject: | |
Same here. Sorry about before, I couldn't select raw voltage and plx was new, so I assumed that was what needed testing. |
Author: | Synoptic [ Sun Oct 16, 2005 11:37 pm ] |
Post subject: | |
Fixed again, see first post for update. |
Author: | White_Teg [ Mon Oct 17, 2005 2:01 am ] |
Post subject: | |
I just ran out to test this quick. The raw voltage seems to work great (stock O2 anyways), some things that I noticed is that it seems to start loging at about 10 percent of what I had the min TPS set at (eg. set at 10-19 and starts logging at 2, set at 20-29 and starts logging at 3). Another thing I ran into is that when logging sometimes it is like the inputs get stuck when using "log to file" (none of the values change except time). If I uncheck "log to file" the values start changing, but after rechecking it it does the same thing after about 4 lines. Restarting ECU Control usually fixes this for a while. |
Page 1 of 5 | All times are UTC - 5 hours [ DST ] |
