Datalogging not working http://forum.pgmfi.org/viewtopic.php?f=10&t=6893 |
Page 1 of 2 |
Author: | CRXdan [ Tue Aug 23, 2005 7:31 pm ] |
Post subject: | Datalogging not working |
I am using a chipped PM6 on ng60 code. I am using a Nokia DKU-5 cable. It has no inline adaptor but the USB connector is about twice as large as normal so I figure it must be in there. It has 5 wires, Black, White, blue, yellow and red. Tracing the pinouts I have came to the conclusion that black is ground, blue is Receiver, and white is Tranmisster. Hooked up the shielded wire to black and to pin1 on CN3. Hooked up the bluw wire to pin2, and the white to pin 4. I have installed all USB drivers and the computer recognizes the usb device. Ive also made sure that the com port corresponds in both ecucontrol and devicemanager (com 5) I load up ECUcontrol and no data is being recorded, absolutley nothing. Ive tried switching the tx and rx wires but no sucess. Any ideas? |
Author: | robus [ Tue Sep 06, 2005 10:22 am ] |
Post subject: | |
Look I'm trying to figure this out myself but at least I'll bump you up... And while I'm at it - perhaps you know where on earth in the Ecu should one hook up the Wideband's analog output? |
Author: | B16CRXT [ Wed Sep 07, 2005 10:01 pm ] |
Post subject: | |
having problem withmy datalogging as well. Where do I download the software for a USB datalogging cable? |
Author: | CivicDisturbance [ Wed Sep 07, 2005 10:13 pm ] |
Post subject: | |
B16CRXT wrote: having problem withmy datalogging as well. Where do I download the software for a USB datalogging cable?
Nokia Method driver is here Buddy: http://dan-ang.com/pgmfi/USBDrive.zip Regards Chris |
Author: | B16CRXT [ Wed Sep 07, 2005 11:45 pm ] |
Post subject: | |
CivicDisturbance wrote: B16CRXT wrote: having problem withmy datalogging as well. Where do I download the software for a USB datalogging cable? Nokia Method driver is here Buddy: http://dan-ang.com/pgmfi/USBDrive.zip Regards Chris Will that also work for the non-nokia USB cables? I have the USB supplied in xenocron's kit. |
Author: | CRXdan [ Tue Sep 13, 2005 11:23 pm ] |
Post subject: | |
does anyone know how to use this cable? |
Author: | drdisco69 [ Tue Sep 13, 2005 11:40 pm ] |
Post subject: | |
I found the following to work on my DKU-5 cable, although I have a green instead of black: Red - Rx Blue - Tx White - Ground with shield Now all this gives me with every datalogger is junk values, but it seems to be communicating. I haven't tried swapping Rx and Tx yet, I think that will be next. |
Author: | 5speed4life [ Tue Jan 17, 2006 9:34 pm ] |
Post subject: | |
did you get that straightend out? and how? I am having the same problem |
Author: | doubledeala [ Mon Jun 05, 2006 1:50 pm ] |
Post subject: | |
robus wrote: Look I'm trying to figure this out myself but at least I'll bump you up...
And while I'm at it - perhaps you know where on earth in the Ecu should one hook up the Wideband's analog output? wideband signal goes into d14 on obd1 |
Author: | migizzel [ Wed Jun 07, 2006 9:22 pm ] |
Post subject: | |
how about on a obd0? |
Author: | ifly87 [ Mon Jun 12, 2006 11:11 pm ] |
Post subject: | |
So has anybody still figured this thing out? I have the same cable, wired black w/shield to pin 1, white to pin 2 and blue to pin 4, these are at least the right pins right? I followed the directions given by Jim Truett. Another thing, what does j12 do and does it need to be cut?, what do you have your other settings at? Any and all help greatly appreciated, thank you. |
Author: | bluecrxnc [ Mon Jun 12, 2006 11:14 pm ] |
Post subject: | |
ifly87 wrote: Another thing, what does j12 do and does it need to be cut?, what do you have your other settings at?
"RTFW" = Read the Fucking WIKI Direct URL to J12 Info |
Author: | mandopr77 [ Sun Sep 17, 2006 3:42 pm ] |
Post subject: | |
Well I have RTFW and I dont see no stinking J12 on my PR3. I cant get my datalogging to work either. I purchased to COMPSys AD233 that was recomended on the ECU Control website. Everything is hooked up right. I have checked multiple times. |
Author: | pacman [ Sun Sep 17, 2006 6:32 pm ] |
Post subject: | |
mandopr77 wrote: Well I have RTFW and I dont see no stinking J12 on my PR3. I cant get my datalogging to work either. I purchased to COMPSys AD233 that was recomended on the ECU Control website. Everything is hooked up right. I have checked multiple times.
Is yours an obd0 or 1 pr3? |
Author: | holgam [ Thu Sep 28, 2006 2:33 am ] |
Post subject: | |
bump, having datalogging problems as well. will connect, but won't read anything in the ecucontrol plugin for TE. ng60 pm6 + RS nokia cable |
Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
