It is currently Sun Apr 22, 2018 9:51 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: Datalogging not working
PostPosted: Tue Aug 23, 2005 7:31 pm
I am using a chipped PM6 on ng60 code.
I am using a Nokia DKU-5 cable. It has no inline adaptor but the USB connector is about twice as large as normal so I figure it must be in there.
It has 5 wires, Black, White, blue, yellow and red. Tracing the pinouts I have came to the conclusion that black is ground, blue is Receiver, and white is Tranmisster. Hooked up the shielded wire to black and to pin1 on CN3. Hooked up the bluw wire to pin2, and the white to pin 4.
I have installed all USB drivers and the computer recognizes the usb device. Ive also made sure that the com port corresponds in both ecucontrol and devicemanager (com 5)
I load up ECUcontrol and no data is being recorded, absolutley nothing.
Ive tried switching the tx and rx wires but no sucess. Any ideas?
PostPosted: Tue Sep 06, 2005 10:22 am
Look I'm trying to figure this out myself but at least I'll bump you up...
And while I'm at it - perhaps you know where on earth in the Ecu should one hook up the Wideband's analog output?
PostPosted: Wed Sep 07, 2005 10:01 pm
having problem withmy datalogging as well. Where do I download the software for a USB datalogging cable?
PostPosted: Wed Sep 07, 2005 10:13 pm
Nokia Method driver is here Buddy: http://dan-ang.com/pgmfi/USBDrive.zip
Regards
Chris
PostPosted: Wed Sep 07, 2005 11:45 pm
Regards
Chris
Will that also work for the non-nokia USB cables? I have the USB supplied in xenocron's kit.
PostPosted: Tue Sep 13, 2005 11:23 pm
does anyone know how to use this cable?
PostPosted: Tue Sep 13, 2005 11:40 pm
I found the following to work on my DKU-5 cable, although I have a green instead of black:
Red - Rx
Blue - Tx
White - Ground with shield
Now all this gives me with every datalogger is junk values, but it seems to be communicating. I haven't tried swapping Rx and Tx yet, I think that will be next.
PostPosted: Tue Jan 17, 2006 9:34 pm
did you get that straightend out? and how? I am having the same problem
PostPosted: Mon Jun 05, 2006 1:50 pm
wideband signal goes into d14 on obd1
PostPosted: Wed Jun 07, 2006 9:22 pm
how about on a obd0?
PostPosted: Mon Jun 12, 2006 11:11 pm
So has anybody still figured this thing out? I have the same cable, wired black w/shield to pin 1, white to pin 2 and blue to pin 4, these are at least the right pins right? I followed the directions given by Jim Truett.
Another thing, what does j12 do and does it need to be cut?, what do you have your other settings at?
Any and all help greatly appreciated, thank you.
PostPosted: Mon Jun 12, 2006 11:14 pm
"RTFW" = Read the Fucking WIKI
Direct URL to J12 Info
PostPosted: Sun Sep 17, 2006 3:42 pm
Well I have RTFW and I dont see no stinking J12 on my PR3. I cant get my datalogging to work either. I purchased to COMPSys AD233 that was recomended on the ECU Control website. Everything is hooked up right. I have checked multiple times.
PostPosted: Sun Sep 17, 2006 6:32 pm
Is yours an obd0 or 1 pr3?
PostPosted: Thu Sep 28, 2006 2:33 am
bump, having datalogging problems as well. will connect, but won't read anything in the ecucontrol plugin for TE. ng60 pm6 + RS nokia cable
