It is currently Tue Apr 16, 2024 7:10 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 60 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: datalog cable
PostPosted: Tue Sep 27, 2005 12:55 pm
I bought this Nokia cable from ebay:
http://cgi.ebay.com/USB-Data-Cable-DKU- ... dZViewItem
I wired it up using Jim's schem.
steps:
cut the phone plug off
you will have 5 wires (black, white,red,blue and green)
I used 3 (black, white and blue)
Black=ground goes to pin 1
white=Tx goes to pin 4
Blue=Rx goes to pin 2
thats all.
I just wanted to let everyone know that this cable is good and its easy to use.
PostPosted: Tue Sep 27, 2005 2:31 pm
sweet thanks.. does it work good for datalogging? have u tried it out?
radio shack(the souce by circuit city) doesnt sell the 170-0787 cable anymore u have to buy the whole kit or some gay shit
PostPosted: Tue Sep 27, 2005 2:36 pm
yes, it works good.
I tried it last night on Ecu control and Freelog.
I will be doing some runs today after reading up on EC.
The only thing is that on EC the gauges are not fine tuned. Like my boost gauge reads 5psi, but in EC it says 6.3Psi. ??
also, Vtec is always off, when I know its actually on.
other than that, good.
PostPosted: Tue Sep 27, 2005 2:39 pm
only thing i noticed is the after market cables do not have that little box on the cable? is that box the TTL ?
Do the after market cables work ok with out that box?
PostPosted: Tue Sep 27, 2005 2:46 pm
this cable has the Prolific PL-2303 chip inside the cable. Its actually on the USB connector side not on the phone side.
You have to really play with the cable trying to find the tx and rx. If you actually purchase the same cable I did. You can use my setup.
just, remember to wire it up to your ecu on CN2. Cn2 has 5 pins. you are only going to use 4. I wired it and wired my WB to the O2 input and done.
let me know if you need anymore assitance or guidance.
PostPosted: Tue Sep 27, 2005 2:50 pm
thanks man... im very knew to this so still learning.. its been a pain talking to radioshack trying to find it since they dont sell just that cable alone anymore :@
at least in canada
PostPosted: Tue Sep 27, 2005 2:54 pm
sure man, I can see you only have 3 post so far so I know how it feels.
Just an FYI, I will suggest, read,read,read. The wiki us and awsome place to learn and just read up on things.
We have all been there at one point or another. so its all good.
Btw, what ecu and setup you have?
PostPosted: Tue Sep 27, 2005 4:12 pm
p06 ... converted to p28 w/ crome
built b16 turbo
PostPosted: Tue Sep 27, 2005 4:16 pm
nice. Same here.
PostPosted: Tue Sep 27, 2005 5:50 pm
using the PLX m500 wideband.
hopefully works ok.
*waits on stupid cable*
PostPosted: Tue Sep 27, 2005 6:18 pm
i have the m300
PostPosted: Tue Sep 27, 2005 9:56 pm
do you mean 3 pins not 4?
i only see 3 pins being used
PostPosted: Wed Sep 28, 2005 10:24 am
yes pin 1-2 and 4. I used an amp italy connector male board mount. there are 5 pins on the board. You would have to get a 4 pin connector and just ignore pin 3. Unless you run the wires directly to the ecu. I like the option to remove and install as I see needed. Thats why I went with the connector.
sorry about the confusion.
PostPosted: Wed Sep 28, 2005 3:48 pm
thanks for clearing that up haha. np
yah i just soldered it to the board.
How long did it take you to get the cable? i just ordered it last night.
PostPosted: Fri Sep 30, 2005 5:01 pm
i have the exact same cable and here is what worked for me
pin 1 : White and ground
Pin 2 : red
Pin4: blue
