It is currently Sun Apr 22, 2018 9:50 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Aug 21, 2005 9:00 pm
ill help ya out charles...basiclly what i had told him was that the map column headings are diffrent so for instance i couldnt just throw in stock pm7 values into the ng60 rom on NA and itll run fine. charles just wants his car to run like stock but beable to datalog and view the details.
PostPosted: Mon Aug 22, 2005 9:46 am
Voltage for AFR please? 0-50 still doesnt mean as much as id want it to, particular for those with WB where map trace with real AFR figures (n lambda or AFR not 0-50 scale) is a VERY powerful tuning tool, particularly for part throttle :D
PostPosted: Fri Sep 09, 2005 7:34 am
When do we expect to get map tracing? And also knock logging?
When's the next version coming out?
PostPosted: Fri Sep 09, 2005 7:59 am
map trace is actually working
theres a thread about it
PostPosted: Fri Sep 09, 2005 6:58 pm
Oops i meant for OBD1 ECU's.
PostPosted: Fri Sep 09, 2005 7:00 pm
Site Admin
yeah, I gotta get on that. I aint have time to code anymore. i know it suxx.
PostPosted: Wed Sep 14, 2005 11:15 pm
Support for 2.5bar etc... sensors. I went to test the working of the last version and it did... but readings for my setup are off with my 2.5bar. An option for alternate Maps would be awesome.
PostPosted: Tue Sep 20, 2005 1:53 pm
Would be awesome with map trace and my LC1, drive round to make a 'AFR map' that you can use to optimise the fuelling.
Maybe then a editable conversion table to turn the volatage into real AFR readings. Would be a real step forward for OBD0 tuning.
PostPosted: Thu Oct 27, 2005 9:23 pm
i would like to see a scrollable or scalable guage interface, or an interface where you can choose which guages you have and where they are displayed in the interface. i can help program these things,even though my c and c++ skills are rusty.
PostPosted: Sat Nov 05, 2005 12:22 pm
I am running this on a PG7 ecu with PM7 maps, on the NG60 base map. I use TE/ECU Control on a Nokia USB datalog cable. It works fine for me on my D16A1 (similar to ZC).
Anyway something I would really like to see on here has already been mentioned. But some sort of fuel economy calculator that works in real time. Have it also show how far you can go on the current tank of gas. And any other "luxury car" type options that they have for keeping track of fuel economy.
I also wish it had a memory function to remember how I setup my O2 sensor to read. It seems I have to set it every time I open it up.
Also on the Palm version it may be nice to have some gauges show on there.
Customizable gauge placement would be nice as well. Also the option for different speed caps. My speedo on the car goes to 220, but on the gauge it only goes to 180.
PostPosted: Sat Nov 05, 2005 12:35 pm
double post :oops:
PostPosted: Thu Nov 17, 2005 7:50 am
Can there be a version of ECUcontrol made to fit a 800x600 cuz that all my laptop can surport that would be great. I cant see all off ECU control.
PostPosted: Tue Jan 17, 2006 5:59 am
i dont know if you're working on it at all, but i was wondering if the raw data function would work on non-commercial wbo2's i.e. raw analog data directly from the sensor..... i figured you could pay 50 for the sensor instead of 199 for an lc-1......might make tuning more affordable??
PostPosted: Wed Feb 22, 2006 1:53 pm
I think that insted of haveing the only download at ecucontrol.com, there should be severl places to download ecucontrol, like pgmfi, xenocron. the http://www.EcuControl.com is alway busted
PostPosted: Sat Sep 09, 2006 9:47 am
Huh? :?
