It is currently Sun Aug 19, 2018 4:35 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Jun 06, 2005 9:57 am
Personally id like to see the lambda voltage in the AFR box rather than the current 0-50 range.
Cheers
PostPosted: Mon Jul 04, 2005 6:39 pm
Same, or ability to put in voltagel range for AFR ratio's so we can see straight ratio's i still cant figure out what this 0-50 is....
PostPosted: Thu Jul 14, 2005 12:59 pm
mynameistin wrote:
cel detector...so if the computer throws for instance a code 10 itll show you that the computer is throwing code 10 and its the IAT or whatever.
EXCELLENT SUGGESTION!
PostPosted: Fri Jul 22, 2005 10:49 am
Corrispondence with the computers actual time, like 4:30.25PM.
Nice to corrispond with my WB Logger that take the Computers time like this.
PostPosted: Fri Aug 12, 2005 12:28 pm
User definable WB input Equation.
My WB is non-linear, but I have a very accurate equation to convert the voltages into AFR,
Either that or just a WB Voltage Log.
PostPosted: Thu Aug 18, 2005 5:23 pm
Full compatibility with OBD0.
PostPosted: Thu Aug 18, 2005 6:54 pm
Site Admin
what do you mean ?
PostPosted: Thu Aug 18, 2005 7:03 pm
I have been told that the ECUControl and turboedit do not work well with NG60. I have a socketed PM6 with Nokia USB cable on an OBD0 NA DOHC ZC. I would love to use ECUControl to datalog and then burn with TurboEdit.
PostPosted: Thu Aug 18, 2005 7:05 pm
Works fine with me. USB, TE/ECUControl, PM6, NG60, DOHC ZC Turbo
PostPosted: Thu Aug 18, 2005 7:09 pm
I heard that Turbo is not a problem. But for NA it is. Of course, I could have heard wrong. Anyone using it on a NA engine?
PostPosted: Thu Aug 18, 2005 7:11 pm
Should be no difference.
The MAP are just extended. Overall code and adressing should be the same.
PostPosted: Thu Aug 18, 2005 8:11 pm
Here's what worried me:
Stock:
NG60
See how different the values are?
PostPosted: Thu Aug 18, 2005 11:11 pm
Site Admin
The Default MAP that comes with N60 is not based ona PM6. It's based on Blundar old old old old map for 440CC..
PostPosted: Thu Aug 18, 2005 11:45 pm
I uess what worries me is the heading on the MAP that is different from the stock MAP. Does it calculate the same? I'll burn a NG60 and check it out.
I just wanted to see if any NA guys have used it.
PostPosted: Fri Aug 19, 2005 11:51 am
You need to use the boost portion really such that the first column is still NA Vac. On the dyno with map trace i had an NA car map tracing the 1.1psi column at WOT. The columns are no means spot on
