It is currently Fri Mar 29, 2024 6:55 am
PostPosted: Sun Nov 05, 2006 8:55 am
I'v made datalogging interface on my P30JDM (smal case), but it not work... when I testing communicatnion on hyperterminal with shorted J4 (J12 on USDM ECU's) echo works fine, so interface is ok; but when trying starts datalogging on ecucontrol, have no readings; same on uberdata; On Crome - RTP comminication test fail; My setup:
- Interface (DKU-5 cable) - Oti006858 with oryginal drivers (not compatible with 2303)
- Open J4 jumper
- Eprom with Crome 1.2 Quick Datalogger+RTP
Any ideas to solve problem?
THX
Artur
PostPosted: Sun Nov 05, 2006 2:33 pm
Problem solved partially - CN2 description on ecucontrol homepage is erroneous - Pin2 is RX and Pin4 is TX - veryfied with 66207 datasheet - Pin2(CN2) is directly connected to pin 39(66207) which is RX input. After wires exchange datalogging works, but only under uberdata; ecucontrol generate error 8020 and shutting down, when i try to start logging; with crome connection test makes no results...
any ideas?
Artur
