It is currently Fri Mar 29, 2024 1:36 am
PostPosted: Sat Jul 29, 2006 11:13 pm
OK i am having a lil bit of problem, I cant seem to get ecucontrol connect with my computer, I bought a USB cable for Nokia 6101 phone, first i try to use the driver that is here USBDRIVER.zip, but my computer cannot find the cable with that driver, so i uninstalled and install the driver that came with the cable, and now it knows there is a usb data cable, the cable is a bit different than those described here, it only have 3 wires, yellow, blue and white , so used a mutimeter check for ground and i found blue and white has 3v and the yellow is a the ground, i swapped tx and rx wires a few times and it didnt help, i reinstalled ecucontrol aslo just incase, also i remove j12, checked all connection it is all good, i have no solution here, someone please give me some adivse. just a thought of mine, maybe the cable i got is not the right conversion??? also i set both computer and ecucontrol at com4, 9600 and 38400 8,n,1, checksum removed, p30 map, p03 hack byte removed, and datalogging enabled
PostPosted: Tue Aug 01, 2006 2:11 am
anyone? any ideas?
Users browsing this forum: No registered users and 10 guests
